| Author |
Message |
| 89liftedxj |
Posted: Thu Aug 20, 2009 10:27 pm |
| looks good man. sick scooter. |
_________________ Authorized Dealer
Polini/Malossi/Doppler/NCY/POSH/YSS/Dr Pulley
www.proscooterparts.com |
| Back to top |
| Mexicano |
Posted: Fri Aug 21, 2009 7:32 am |
89liftedxj wrote: looks good man. sick scooter.
Thanks! |
_________________ ‘There is only one secret in scooter tuning – to know what you are doing and do it thoroughly’ |
| Back to top |
| C-kell |
Posted: Sun Feb 14, 2010 11:11 pm |
| Great scoot Mexicano.The stand you made is brilliant.I would like to make something similar.Thanks for the inspiration. |
_________________ C-Kell |
| Back to top |
| Mexicano |
Posted: Mon Feb 15, 2010 7:06 pm |
C-kell wrote: Great scoot Mexicano.The stand you made is brilliant.I would like to make something similar.Thanks for the inspiration.
Thanks!....I'm glad You liked my bike.....I will be building a more powerfull 100 c.c. engine soon, keep tuned! |
| Back to top |
| Jame |
Posted: Thu Feb 25, 2010 11:32 pm |
| Very cool scooter + customizations. Will be showing this to my friend, he is getting a MZ soon, will need to relocate the front and rear signal lights, original position is ugly. |
| Back to top |
| kwaad2 |
Posted: Wed Mar 10, 2010 3:46 pm |
Mexicano - Amazing upgrades.
In regards to the LED lights, I'm not sure how well this would work, but I know ther are some *REALLY* bright LED light fixtures for "trailer lights" that you can pickup at truckstops, and sometimes a little cheaper, at a truck shop. Most of the lights have dual-power lines going into them. (brake lights, signal lights, etc) You could cut the "light" out of the "sealed fixture" and then place it basically anywhere you want, and their fairly reasonably priced. I need to take the front off my F12 and see if I can do something like that for my lights, as I have an american model, and the lights are ALWAYS on, and I think I'm having battery issues, because of that. Another type of LED light, and this could be BRIGHT. (think questionable road legality).
You can get a 1watt Luxeon bulb HERE. They will emit about 120 lumes at 3.5volts. (meaning a single bulb, would be about 1/3rd a 20watt halogen bulb) I would string a pair of 3 to 4 of them on a circut board, to desired brightness. once you get it wired, I'd cover everything in hot glue. (except the bulbs) to protect form the elements as best as possible. If everything would work as planned, you could get 25% more light than the halogen bulb, with nearly 1/6th the power. But dont ask me about how to build that setup just yet, as I'm not going into the hard part in my head. (getting the voltage set right)
But for front facing lights, I would think that would be about as good as you can get.
EDIT: There's a thing called "LED Power Puck" that will get the voltage where you need it. |
| Back to top |
| Mexicano |
Posted: Wed Mar 10, 2010 5:00 pm |
kwaad2 wrote: Mexicano - Amazing upgrades.
Thanks!
kwaad2 wrote: In regards to the LED lights, I'm not sure how well this would work, but I know ther are some *REALLY* bright LED light fixtures for "trailer lights" that you can pickup at truckstops, and sometimes a little cheaper, at a truck shop. Most of the lights have dual-power lines going into them. (brake lights, signal lights, etc) You could cut the "light" out of the "sealed fixture" and then place it basically anywhere you want, and their fairly reasonably priced. I need to take the front off my F12 and see if I can do something like that for my lights, as I have an american model, and the lights are ALWAYS on, and I think I'm having battery issues, because of that. Another type of LED light, and this could be BRIGHT. (think questionable road legality).
EDIT: There's a thing called " LED Power Puck" that will get the voltage where you need it.
In regards of the front led lighting, I got this better option for my Son's bike, less hassle:
http://www.scooterinvasion.net/forum/viewtopic.php?t=1497 |
| Back to top |
| kwaad2 |
Posted: Wed Mar 10, 2010 5:37 pm |
Possibly easily especially if you can get a bulb that fits your bike.
However in regards to difficulty, some crazy glue, hot glue, so soldering, some fine wire, and a small piece of circuit board from radio shack, and about 30 minutes of your time to build the board, and then I would just tear the bulb off your old bulb. (preferably a dead one) Connect the leads from the old bulb base to the the puck, hot glue it all together, and crazy glue it to the old bulb base. (if you can mange to get it small enough, another thing I'm not sure of) and optimally, try to find a way to "seal" the electronics/LEDs. And you would if I'm not mistaken, have something close to a HID light, but LED. I'm gonna leave it at that here, and see if I can come up with 100 or so $ to retrofit the lights on the front of my R12, if I do, I'll do a guide. (not promising anything, but I like bright headlights, and their not that great right now) |
| Back to top |
| Mexicano |
Posted: Wed Mar 10, 2010 5:57 pm |
If You really want to fabricate your own Led head light, this is a good option, 700 lumens, 12 vcd:
http://www.terraluxcorp.com/terralux/Products/Portable/Upgrades/TLE300MEX/tabid/86/Default.aspx |
| Back to top |
| kwaad2 |
Posted: Wed Mar 10, 2010 7:05 pm |
| Back to top |
| Mexicano |
Posted: Wed Mar 10, 2010 10:00 pm |
Take into consideration that this led wont have hi/lo beam, with the TerraLux TLE-300 you can turn into 3 different beams. |
| Back to top |
| kwaad2 |
Posted: Wed Mar 10, 2010 10:26 pm |
Your actually right on that...  |
| Back to top |
| Mexicano |
Posted: Sat Mar 27, 2010 9:30 pm |
| Back to top |
| Mexicano |
Posted: Fri Jun 18, 2010 1:51 pm |
Surfing the web, I saw this little thingy; An Axle Puller, I didn't know what It was for, but my good friend Jon Mathison told what are those for and said they were very comun in Japan for racing bikes, then he nicely offered to get me one.
After some search, he couldn't find a D-Bros Axle Puller for scooters (10 m.m. or 12 m.m. axle), only 17 m.m. or 21 m.m. (for big bikes), the only ones available for scooters were Chinese stuff , I decide to ask him to buy me the real one and try to fix it, here is how I did:
You can see the large ID of the puller:
This is my 12 m.m. axle:
Main issue with this puller is that it "hits" the fork because the size:
Easy task for my small lathe, let's fabricate an "adapter" for this puller:
Ready!
Installed:
I'm not gonna "use" this puller very often, maybe never...but it looks nice! |
| Back to top |
| C-kell |
Posted: Sun Jun 20, 2010 5:02 pm |
| Cool.Looks like it would provide some crash protection as well. |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
