Silly Tao Tao carburetor... (Photos)
Postby Areomyst » Tue Jan 24, 2012 9:42 pm
So, this is the second carburetor from "Tao Tao" (another knock-off no-name Chinese scooter) that I have had to do this with. They come in needing carb work and you're ready to rock and get the carb cleaned... only to be hindered by those little torque shear/security snap-off bolts! Now, i'm used to seeing these on thing like ignition keyswitches, and components that aren't supposed to be removed, but...
Well, ya can't really remove them easily like this...
So I cut a small slot in the shear bolts with my dremel, and used a flat-head screwdriver to get them out. It worked well enough, but was a pain in the butt for a simple carb cleaning.
The other one that I had in, I drilled a small pilot hole, then drilled a size up, and then used a screw extractor. It was quite a bit more time consuming than the "cut a slot - use a flat-head" method, but was probably the better way to go. When I put the screw back in there was a little bit of material removed from the carb bowl as a result of how I was cutting the bolt. In this situation it really didn't matter, but it got under my skin anyway:
Thanks for looking!
Postby zombie » Fri Jan 27, 2012 12:12 am
This will help w/ all sorts of striped heads, and such... Reverse twist drill bits. They are easily found, and will bite in just like an extractor. In fact 90% of the time you won't need an extractor at all if you use them. Maybe a good one for the tool thread.
Postby Areomyst » Fri Jan 27, 2012 6:45 am
zombie wrote:This will help w/ all sorts of striped heads, and such... Reverse twist drill bits. They are easily found, and will bite in just like an extractor. In fact 90% of the time you won't need an extractor at all if you use them. Maybe a good one for the tool thread.
Good to see you here sir. :)
I've used the reverse drills quite a bit in the past, and yes, they really do work well. It wouldn't be a bad idea to pick some up, that's for sure!
Ciao,
Postby Areomyst » Fri Jan 27, 2012 6:48 am
It's funny, because I posted those pictures and then Wednesday I had ANOTHER carburetor with the same darned thing going on. This was a "VIP" scooter... another China no-name thing, with hardly any miles on it. It's almost like they're trying to equip these things with a disposable carburetor.
This time I drilled and used a screw extractor instead of cutting a slot. I'll upload photos later.
Postby 2strokd » Fri Jan 27, 2012 9:43 am
Ive noticed this on the newer model 2T mina powered scoots around here as well. I could get the bowl off but the main jet wasnt removable :( . The whole carb was about the cheapest ive seen. I have seen better built things come out of the bottom of a box of cereal :roll:
Postby Areomyst » Fri Jan 27, 2012 10:06 am
2strokd wrote:Ive noticed this on the newer model 2T mina powered scoots around here as well. I could get the bowl off but the main jet wasnt removable :( . The whole carb was about the cheapest ive seen. I have seen better built things come out of the bottom of a box of cereal :roll:
Wanna do a group buy on Dellorto shares? :twisted: :twisted: :twisted:
Removing screw from chinese carburetor, VIP Peace Sport, Tao
Postby Areomyst » Sat Jan 28, 2012 9:17 pm
Here are some photos from the other one... good grief.
Guess I'll stock up on replacement machine screws as this seems to be popular lately. What a pain in the arse.
wireburn
Postby wireburn » Mon Jan 30, 2012 9:31 am
Josh, now bear with me, I'm not trying to be harsh, but, how much are these stock carbs, really? Actually, I know...dealer price can be lower than $10 ea. Why even waste time on these? For the amount you'd need to charge a customer to perform this "repair" they could have a decent stock replacement complete with bowl screws. :roll:
-Mike
2007 Ruckus BIG BORE
2002 Metropolitan II w/Ruckus Swingarm
2006 Yamati Strada RX8 103cc LC stroker, PG power pipe, Keihin PWK28, Custom Intake, V-Force3 MX Reeds, Polini 14/41, Malossi OR, DC conversion (Sold!)
2000 Harley-Davidson Road King Classic
Postby Areomyst » Mon Jan 30, 2012 8:10 pm
wireburn wrote:Josh, now bear with me, I'm not trying to be harsh, but, how much are these stock carbs, really? Actually, I know...dealer price can be lower than $10 ea. Why even waste time on these? For the amount you'd need to charge a customer to perform this "repair" they could have a decent stock replacement complete with bowl screws. :roll:
-Mike
Lower than $10 each? Damn...
If I need to replace one, I order a Walbro from IDC, they retail around $60. Carburetor replacements for me are rare though as they can usually easily be cleaned quickly.
I charge one hour to clean the carb, and while I'm in there I also do little things, like check the tire pressure, adjust cables, etc... It's followed up by a test drive, and I feel like it's a good value... If lots of people didn't feel that way, I probably wouldn't be getting the work.
Where is the $10 carb from? If it's a vendnor I'm set up with, I'll order a couple and give them a try. I've always been of the mindset of "repair instead of replace" for most work.
Postby Areomyst » Mon Jan 30, 2012 8:14 pm
Also, I hoped that posting up the photos might help someone in a jam if they need to clean their own carb, and they weren't sure about getting the screws out. Fixing it 'right now' is better than waiting on a parts order if you can fix it right.
wireburn
Postby wireburn » Tue Jan 31, 2012 6:04 am
Much as I hate to promote him, the dealer pricing list I saw came from scootersus.com.
Checking the list again, I see I was off, carbs are $25 or $30 for the 150's. PM'ed you the list.
-Mike
Postby Areomyst » Tue Jan 31, 2012 7:33 am
wireburn wrote:Much as I hate to promote him, the dealer pricing list I saw came from scootersus.com.
-Mike
Cool, I'll check that out thanks. :) $25 to $30 still is a ridiculously low price.
While I was browsing around, I even found a cheap 50cc one from Partsforscooters! RETAIL for $25?!? Now, they're not normally that low, but I guess they don't have the accelerator pump...
http://www.partsforscooters.com/151-235 ... r_qmb139_2
Happy scootering!
Postby zombie » Tue Jan 31, 2012 8:09 pm
http://www.ebay.com/sch/i.html?_from=R4 ... Categories
http://www.alibaba.com/showroom/gy6-carburetor.html
You all have to spend more time looking! The whole engine is $79.00 w/ Carb. I like the "Future Champion" logo. Kinda like "Faster than Speed!" Or "Louder than Sound!"
What else you need?
dirtyd
Postby dirtyd » Tue Jan 31, 2012 9:01 pm
zombie wrote:http://www.ebay.com/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=gy6+carb&_sacat=See-All-Categories
What else you need?
"Not only supply all kinds of carburetors, but also can develop new carburteors for our customers..."
Haha, that's funny...
'05 MZ Moskito
'06 SYM Jet Euro X 72cc
'09 Kymco Agility 50
'?? POS chinese gy6 junk
Tacos
Postby zombie » Thu Feb 02, 2012 8:36 pm
I kinda agree w/ wireburn on this one. It would be cheaper/ easier to order a "box o carbs" and sell them out at 50 bucks installed. In MY business i sell parts/items at cost, and make my $'s on the install labor. I can generally (98%) do a whole job for less than others sell the part for. Soooo I stay REAL busy. Ps I build/restore/repair boats in a town FULL of marine supply/repair shops. Competition HATES me, Customers line up!
Users browsing this forum: No registered users and 5 guests
