Scooter Forum and Messageboard by Scooter Invasion Forum Index
Author Message
<  Scooter Showroom  ~  Hamaha
Posted: Sat Jan 23, 2010 11:53 pm Reply with quote
Joined: 08 Oct 2009 Posts: 397 Location: N.W. Florida
MMMaaannn That is gonna be too much fun. Awesome
We may see it but, occasionally... it must be pointed out
View user's profile Send private message Send e-mail
wireburn
Posted: Mon Jan 25, 2010 12:29 pm Reply with quote
Joined: 07 Jan 2008 Posts: 225 Location: Muskegon, MI USA
Areomyst wrote:
wireburn wrote:
It's a stuffer. Supposed to speed airflow into the case.
-Mike
Woah! Good to see ya Mike. Smile
Hey, thanks. More lurkin' than postin' in the dead of Michigan winter...
-Mike
2006 Yamati Strada RX8 103cc Char-mo stroker kit, PG power pipe, Keihin PWK28, titanium intake/cage, carbon fiber reeds, Polini upgear
2001 Malaguti F12 LC, Stock (for now)
2000 Harley-Davidson Road King Classic, Stage 2
Enviromoto
Posted: Mon Jan 25, 2010 8:33 pm Reply with quote
Brakes and speedo sensor mounted.
A few little things buttoned up.
A little test fit, and it wont be crooked after I actually mount it Smile
www.Enviromoto.com
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Posted: Mon Jan 25, 2010 10:04 pm Reply with quote
Heads up on the spark plug boot! It is a hard plastic (styrene maybe), and will not hold up. Mine lasted about a month, and cracked into a hundred pieces. I just went back to the boot from the factory coil. Great coil though!
Enviromoto
Posted: Mon Jan 25, 2010 10:42 pm Reply with quote
10-4 on the heads up, Ill put the stocker back on after I show it off a little bit.
I plan on leaving the battery box stock along with the rear frame to keep the original Ruckus feel. What do you think? Do you like that idea?
www.Enviromoto.com
dio burnout
Posted: Tue Jan 26, 2010 1:00 am Reply with quote
I use the same exact one on my Live Dio AF34 setup, been running it for almost one year with no problems.The only problem I had with the coil was the female wire connector was lose, just squeezed together and put it back on.
Jon M.
How does the burnout taste in your grill.
Enviromoto
Posted: Tue Jan 26, 2010 10:14 pm Reply with quote
Todays task.
Installation of the Polini 9 roller speed kit, 107mm clutch upgrade, Stage 6 R/T clutch bell, and 2000 rpm clutch springs.
Some specs:
Stock variator circumference 94mm
Polini variator circumference 95mm with steeper ramp angle of the drive face.
Stock outer drive face 94mm
Polini outer drive face 95mm matched angle with the variator
The backing plate on the Polini 9 roller speed variator was shallower than the stock unit letting the rollers act upon the backing plate faster.
From my understanding the 9 rollers act faster against the backing plate providing better takeoff without sacrificing top speed.
I went with the 3G rollers which would be 4.5G in a normal setup.
Stage 6 R/T clutch bell has cooling fins and is quite a bit lighter than stock.
Polini Kevlar Belt
Shazam!
My little tail light mod. You cant see it but I replaced the tail light bulb with a led tail light assembly. Also note the scrolling led license plate holder and led turn signals. Cool
I got a bunch more done but its boring cleaning and clearancing of plastic parts. I hope to have this puppy wired up by the weekend.
www.Enviromoto.com
Mexicano
Posted: Tue Jan 26, 2010 10:33 pm Reply with quote
Looking very nice...keep it up!
Regards,
‘There is only one secret in scooter tuning – to know what you are doing and do it thoroughly’
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
Posted: Tue Jan 26, 2010 11:02 pm Reply with quote
SSSsssooooo NICE!
Enviromoto
Posted: Tue Feb 02, 2010 8:47 pm Reply with quote
So here is what Ive been up to for the last couple days.
Laying out the harness before I cut off the loom.
Wires exposed.
Relay wired up. Big thanks to TotalRuckus for the How-To.
Shorting and lengthening wires. Its all back in the loom and cleaned up now but my battery was dead in the camera.
Ended up going with option B.
I thought I was going to put a high flow fan on. Nope it didnt fit so new stock parts are on order.
Heres the problem.
Then I went to install my pipe and it didnt fit.
With only 7 working days left I better get this thing lined out. It would be ok but I keep running into unexpected gremlins. I guess if it was easy everyone would be doing it. Smile
www.Enviromoto.com
dio burnout
Posted: Tue Feb 02, 2010 9:21 pm Reply with quote
Daytona makes the thicker rubber gasket and longer bolts to mount the fan shroud for over sized cooling fans. They make them for both the Dio engines and Jog engines.
Very nice build, scooter is looking great.
Regards
Jon M
Enviromoto
Posted: Tue Feb 02, 2010 10:23 pm Reply with quote
Thank you Jon. This build has been my most challenging one so far. Im learing a ton. Cool
www.Enviromoto.com
Posted: Wed Feb 03, 2010 12:10 pm Reply with quote
Joined: 28 Oct 2009 Posts: 273 Location: Lafayette IN
Your doing a great job J
Wink
01 CPI Misketo MZ- Drag scooter
01 Aprilia SR50 DiTech-Being parted out!
03 Kymco Cobra- Daily driver
C-kell
Posted: Thu Feb 11, 2010 9:18 pm Reply with quote
Did you finish or ride er yet.
C-Kell
Enviromoto
Posted: Sun Feb 14, 2010 11:56 am Reply with quote
FIN
I havent even test fired it yet, gotta make the show circuit first. Cool
www.Enviromoto.com
Display posts from previous:
Page 7 of 10
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Post new topic
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
