| Author |
Message |
| zombie |
Posted: Fri Jan 22, 2010 12:40 am |
| Oh Yeah! Do it right ! Just messing w/ you. I know nothing about that! Just wanted to say HEY!!! You have a couple of cool projects going on, and just had to give some "kudos" Sorry for the side slide. |
_________________ We may see it but, occasionally... it must be pointed out |
| Back to top |
| Enviromoto |
Posted: Fri Jan 22, 2010 11:13 am |
| Hey head is spinnin' too much internet slang for me to comprehend. LMAO! |
_________________ www.Enviromoto.com |
| Back to top |
| Enviromoto |
Posted: Fri Jan 22, 2010 11:00 pm |
Got the top end, oil seals, and a few other odds and ends cleaned up today.
Now I have a decision to make.
Option A.
to use the Stage 6 intake spacer with the 19mm Dellorto I have to remove the electric starter.
Option B.
Use this intake.
Im thinking option A for the expo and option B for when I actually ride and tune this thing. |
| Back to top |
| zombie |
Posted: Fri Jan 22, 2010 11:05 pm |
| A looks as if there is too much of an angle on the carb! the float may never work. B would be slightly less power than a short manifold but would be easier to tune. "a" looks sooo frigin cool though! |
| Back to top |
| Mexicano |
Posted: Fri Jan 22, 2010 11:20 pm |
| Back to top |
| Enviromoto |
Posted: Sat Jan 23, 2010 12:05 am |
Some damn fine work Mexicano, damn fine.
Zombie if I remove the starter it will be at a better angle. From what I read the dellorto can handle up to a 45 degree angle. |
| Back to top |
| Mexicano |
Posted: Sat Jan 23, 2010 12:08 am |
Enviromoto wrote: Some damn fine work Mexicano, damn fine.
Thanks! |
_________________ ‘There is only one secret in scooter tuning – to know what you are doing and do it thoroughly’ |
| Back to top |
| 6'6"ninja |
Posted: Sat Jan 23, 2010 12:18 am |
| I think you are missing the alum spacer that goes with that s6 manifold. It might come by itself. If you dont know what i am talking about I can put up a link. |
| Back to top |
| Enviromoto |
Posted: Sat Jan 23, 2010 12:43 am |
| Back to top |
| 6'6"ninja |
Posted: Sat Jan 23, 2010 3:45 am |
| Ya thats the one im talking about. I always liked the look of that manifold but didnt know you had to take off the starter. Good to know as I dont think they tell you that in the add on scooterattack |
| Back to top |
| Enviromoto |
Posted: Sat Jan 23, 2010 1:15 pm |
We started out today installing gears.
I ordered a set of Stage 6 13/43 primary drive gears as I wanted to test them out before I put them in my webstore.
First thing I had to do was install the oil seal. It just pushes in by hand. You want to use a little grease on the outer edge and inner lip before installation.
Then we had to install all new bearings.
You can use a bearing installer tool like this one but I prefer the press.
Bearings installed.
Now we find a problem. The Stage 6 gears dont fit. The box says for a MBK Booster. From the S6 website I ordered the right ones so Im at a loss why they dont fit. I mean I know why they dont fit the outside diameter of the gear is 1mm to large and the end that fits into the bearing is 2mm to large. I just thought S6 had their stuff together. This is why I R&D my products before I bring them to market.
Looks like we are running the stock gears for now.
Here is the rubber spacer I had to use to install the carb into the intake. Appears to work good with no leaks.
I installed the Buzzeti kickstand and it was very simple. Just one bolt and your done. Well made also.
Font end on.
Motor mounted, tires on, and a little sneak peek of things to come.
| Back to top |
| Enviromoto |
Posted: Sat Jan 23, 2010 9:08 pm |
BTW what is this for? It fits inside the Polini reedcage.
| Back to top |
| wireburn |
Posted: Sat Jan 23, 2010 9:17 pm |
It's a stuffer. Supposed to speed airflow into the case.
-Mike |
_________________ 2006 Yamati Strada RX8 103cc Char-mo stroker kit, PG power pipe, Keihin PWK28, titanium intake/cage, carbon fiber reeds, Polini upgear
2001 Malaguti F12 LC, Stock (for now)
2000 Harley-Davidson Road King Classic, Stage 2 |
| Back to top |
| Areomyst |
Posted: Sat Jan 23, 2010 10:43 pm |
wireburn wrote: It's a stuffer. Supposed to speed airflow into the case.
-Mike
Woah! Good to see ya Mike.  |
_________________ TSG Tuning (Updated January 31st, 2010. More updates coming soon!) |
| Back to top |
| Enviromoto |
Posted: Sat Jan 23, 2010 10:50 pm |
| Thanks for the info. I thought it was a restriction of some sort. |
| Back to top |
