Scooter Forum and Messageboard by Scooter Invasion Forum Index
Author Message
<  Scooter Showroom  ~  C-Kells zuma
C-kell
Posted: Mon Jul 19, 2010 12:08 am Reply with quote
Long story short I made my first mold and my first carbon fiber part.It was an experiment.Next time I think I know enough now to make a nice part.Here are pics after it came out of the mold.
C-Kell
View user's profile Send private message
dio burnout
Posted: Mon Jul 19, 2010 5:31 am Reply with quote
Sweet, did you vacuum bag the mold ? looks really nice.
regards
Jon M.
How does the burnout taste in your grill.
Mexicano
Posted: Mon Jul 19, 2010 7:35 am Reply with quote
Very, very nice!!!, please post pics from the process...I'm very interested on this. Where did You get the materials???
Thanks!
‘There is only one secret in scooter tuning – to know what you are doing and do it thoroughly’
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
C-kell
Posted: Mon Jul 19, 2010 3:19 pm Reply with quote
regards
Jon M.
No.I would like to try out a vacuum set up.I used this as my guide. http://www.thumpertalk.com/forum/archive/index.php/t-732185.html.Its not really that hard to do its just time consuming and materials are expensive.
C-Kell
C-kell
Posted: Mon Jul 19, 2010 3:27 pm Reply with quote
Thanks!
Thanks Mexicano.Those are the only pics I have.You could totally do it.I just did a lot of research before i started.I like to be well prepared when I take on a project such as this.I get my materials from taps plastics since its local.I had to order the carbon matt.Here are some links http://www.tapplastics.com/shop/product.php?pid=98& Huh I cant find a link for the resin.Basically you want clear epoxy resin.Some people will use pollyester since its cheaper but you will be left with a low quality part.
C-Kell
Mexicano
Posted: Mon Jul 19, 2010 9:03 pm Reply with quote
Thanks a lot!
That was a plastic part just covered with the carbon fabric, right?
Posted: Tue Jul 20, 2010 9:53 am Reply with quote
Joined: 28 Oct 2009 Posts: 273 Location: Lafayette IN
That is sweet!
Great work Very Happy
01 CPI Misketo MZ- Drag scooter
01 Aprilia SR50 DiTech-Being parted out!
03 Kymco Cobra- Daily driver
C-kell
Posted: Tue Jul 20, 2010 9:36 pm Reply with quote
Mexicano wrote:
Thanks a lot!
No,its just carbon fiber and epoxy.I made a mold or casting of the original part then layed the carbon in the mold. http://www.thumpertalk.com/forum/archive/index.php/t-732185.html Theres alot here but look through this whole link.Use the links on the page too.Everything I know I learned here.You may want to subscribe too so you can see the pics.
C-Kell
C-kell
Posted: Tue Jul 20, 2010 9:40 pm Reply with quote
2strokd wrote:
That is sweet!
Thanks.It was rewarding when I pulled it out of the mold.I wasnt sure how it would turn out.Im happy with the result.
C-Kell
C-kell
Posted: Tue Jul 20, 2010 9:44 pm Reply with quote
Here Mexicano.You can see me making the mold in this link.Go 3/4 of the way down on the page. http://www.zumaforums.net/phpBB3/viewtopic.php?f=50&t=5614&start=195
C-Kell
Mexicano
Posted: Tue Jul 20, 2010 10:34 pm Reply with quote
Thanks a lot C-Kell...
C-kell
Posted: Wed Jul 21, 2010 10:14 am Reply with quote
No problem.Let me know if I can help with anything else.
C-Kell
Mexicano
Posted: Wed Jul 21, 2010 10:40 am Reply with quote
I'm close to get my hands into my new rear mudguard, it is like yours and I'm thinking on "wraping" the black plastic with carbon fiber cloth and a layer of epoxy...Do you think it would work???
Regards,
C-kell
Posted: Sat Jul 24, 2010 5:22 pm Reply with quote
Regards,
Ill run you through what I would do.Go get some poly resin and fiberglass mat.Clean the fender and apply 3 to 4 coats of mold release wax.After the wax is applied put a coat or two of the poly resin on the fender.Once it gets tacky or sticky lay some mat down.This is a very important part.You need to get the mat to lay down completely and get a the air out of the resin.Then contunue to brush on resin and add mat.Three to four layers should be good.You want to use the least amount of resin you can but still get the mat nice and saturated.Once thats dry seperate the mold from the fender.If theres any holes you can drizzle some resin in and sand smooth.I like to mix the resin and put it in a bag and poke a little hole in the end.Like when they put the iceing of the cakes.Hope that makes sence.Oh and the reason I say use poly resin for the mold is its way cheaper .I dont approve of polly for the finished part but for what we are doing its fine for the mold.Ok so now that you have a mold.You do the same thing as you did to make the mold.Lay some wax down on mold,then epoxy resin, then carbon fiber.Just remember its very important to get all the air out and do a good job to get the carbon to lay all the way down.Three layers of carbon should do.What Im going to do next time is kinda make a sandwich.So you would have the mold,then the carbon layers,then the fender and clamp it all together.Thats about it.Im not very god at explaining things.I hope you understand my rambling.Let me know if I need to reiterate something.Do a couple test so you can get the feel for timing with the different resins.Just remember your Mexicano, you can do anything.
C-Kell
Mexicano
Posted: Sat Jul 24, 2010 7:34 pm Reply with quote
Thanks for the time to explain this.
If I understood well, You are saying to "make a mold" out of the plastic mudguard, then use it as a new mold to fabicate the Carbon fiber fender, right?
Question is, Why not use the plastic fender as a "direct mold" for the carbon fiber mud guard?, Is there any reason?
Regards,
Display posts from previous:
Page 5 of 6
Goto page Previous  1, 2, 3, 4, 5, 6  Next
Post new topic
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
